AC86U Upgrade
bilboSNB
Does the AX86U have a faster processor than the AC86U, if not what is the next model up that does and is supported by Rmerlin?
Edit looks like the ax is quad vs the ac dual core, so assuming better open vpn performance? Or is openvpn still single core?
eibgrad
OpenVPN itself is single threaded. It will only perform better to the extent that its access to that thread is NOT being shared w/ other processes due to the availability of other cores by those other processes. Bottomline, unless you're pushing that router to the max for some reason, it's NOT going to make much difference.
GSpock
bilboSNB
If you had to buy one today, which would you pick between the ax88u and the ax86u, if they were both the same price?
MarkyPancake
The AX86U is likely where I'll go next from my AC86U, which has been flawless for the 3-4 years I've been using it so far. It replaced the AC68U, so I should continue with the vertical standing theme really.
