Callipygous
I have an AC87R unit that has a nonfunctioning 2.4GHz band. I cannot log in to the router after the initial setup as the ASUS login page is grayed out and contains a message along the lines of "you've got ASUS firmware on a non ASUS product". Another post mentions this is due to the 2.4GHz band driver failing to load.
I'd like to attempt a repair but would like some guidance. I've fixed obviously broken electronics before (ie. broken solder connections, fried capacitors). Can anyone point me towards schematics that would outline where the 2.4GHz hardware is once I open up the router? Also, any advice about opening these up in general would be great. Thanks!
