AC87U Antennas and Temp
I haven't got temps as I haven't put merlin fw on it just yet. Waiting for an update. But feeling it feels hardly even warm.
Only tells me the CPU temp
Check temp without fan
Wysłane z mojego SM-G850F przy użyciu Tapatalka
3200 should be cooler than 87u becouse 87u has two cpu (3200 only one)
They both have the same dual core CPU
yes but 87u have additional cpu for 5GHz
I'm sure the AC3200 also has 2 separate 5GHZ chips and a separate 2.4GHZ chip?
Yes, but the RT-AC87U has an additional CPU for the 5GHz band. The radio chips are not as warm as the cpu chips are.
Mine runs at (without cooling):
2.4 GHz: 49°C - 5 GHz:65°C - CPU:86°C
Although, my 5Ghz is disabled until it becomes stable...
I also ordered a Cooler Master NOTEPAL X-SLIM II though for the hell of it, will see how much of a difference it makes.
