[AC87U] Firmware 384.4, VPN rules not working
Auguste
Hello,
Since I updated my AC87Uto 384.4, my VPN rules not working. On my device when I check on myip.org, I have the FAI IP and not VPN IP.
What I can do?
Thanks,
joegreat
87U with VPN, no problems here.
Same here: Working perfectly fine (coming from version 380.69_2) and using this approach/rules to redirect traffic to VPN connection.
I did a "dirty" update with no factory reset and re-config after the update. :rolleyes:
Auguste
Thanks,
But I found.
In add of VPN rules, I had a DualWan rules to route all traffic of this device on second FAI.
It seems to take over the DualWan rules on VPN rules.
When I deleted Dualwan rules, It's work.
Auguste
Bad news for me...
I found another problem. The VPN rules works only if dualwan was disabled. When I enable the dualwan, the VPN rules don't work.
Martineau
Part of the Furniture
Bad news for me...
Script /usr/sbin/vpnrouting.sh will need to be patched
e.g. something like this:
        if [ "$TARGET_ROUTE" = "WAN" ]
        then
            TARGET_LOOKUP="main"
            WAN_PRIO=$((WAN_PRIO+1))
            RULE_PRIO=$WAN_PRIO
            TARGET_NAME="WAN"
        else
            TARGET_LOOKUP=$VPN_TBL
            VPN_PRIO=$((VPN_PRIO+1))
            RULE_PRIO=$VPN_PRIO
            TARGET_NAME="VPN client "$VPN_UNIT
        fi
change to
        ########################################################################################## Martineau Hack 2 of 10
        DESC=$(echo $ENTRY | cut -d ">" -f 1)
        #if [ "$TARGET_ROUTE" = "WAN" ]
        if [ "$TARGET_ROUTE" = "WAN" ] || [ "$TARGET_ROUTE" = "WAN0" ] || [ "$TARGET_ROUTE" = "WAN1" ]
        then
            TARGET_NAME="WAN"
            # Allow GUI tagging for Dual WAN i.e. if DESC contains 'WAN1' then use it! - since drop down is 'WAN' only :-(
            # NOTE: WAN0 entries preferably should precede tagged 'WAN1' entries in the GUI as they will share a single priority
            #       although they will both ALWAYS have a higher priority than the VPN entries
            #if [ "$(nvram get wans_mode) == "lb" )];then  # FO (Failover) / FB (Fallback) / LB (Load-Balancing)
            #if [ -z "$(nvram get wans_dualwan | grep -io "none")" ];then
                if [ "$TARGET_ROUTE" = "WAN1" ] || [ ! -z "$(echo "$DESC" | grep -owi "WAN1" )" ];then
                    TARGET_LOOKUP="200"
                    TARGET_NAME="WAN1"
                    my_logger"Dual-WAN will use WAN1 instead of WAN0 (table main)"
                else
                    if [ "$TARGET_ROUTE" = "WAN0" ];then
                        TARGET_LOOKUP="100"
                    fi
                fi
            #fi
            # v382.xx> for Dual WAN etc. uses prio 100,150,200 and 400 :-(
            #WAN_PRIO=$((WAN_PRIO+1))
            WAN_PRIO=$((WAN_PRIO+OFFSET))
            RULE_PRIO=$WAN_PRIO
        else
            ########################################################################################## Martineau Hack 3 of 10
            #VPN_PRIO=$((VPN_PRIO+1))
            VPN_PRIO=$((VPN_PRIO+OFFSET))
            RULE_PRIO=$VPN_PRIO
        fi
and
START_PRIO=$((10000+(200*($VPN_UNIT-1))))
END_PRIO=$(($START_PRIO+199))
WAN_PRIO=$START_PRIO
VPN_PRIO=$(($START_PRIO+100))
change to
########################################################################################## Martineau Hack 9 of 10
# v382.xx> for Dual WAN etc. uses prio 100,150,200 and 400? :-(
FIRMWARE=$(echo $(nvram get buildno) | awk 'BEGIN { FS = "." } {printf("%03d%02d",$1,$2)}')
if [ -z "$(ip rule | grep -Eo -m 1 "^[1|2|4]00:")" ];then
    OFFSET=1
else
    START_PRIO=$VPN_UNIT"0"                     # Limit the VPN Clients to a single rule prio
    END_PRIO=$(($START_PRIO+9))
    VPN_PRIO=$(($START_PRIO+5))
    OFFSET=0                                    # Limit the VPN Clients to a single (multiple) rule prio 10,15 and 20,25 etc.
fi
#VPN_PRIO=$(($START_PRIO+100))
Martineau
Thanks Mr Martineau, but I'm very sorry to ask another question.
How to patch?
I'm connect by ssh, but it's read-only system, and on https://github.com/RMerl/asuswrt-merlin/wiki/Custom-config-files I can't see vpnrouting.sh able to modify.
You can always wait until the issue is formally resolved in the next release by the developer? ;)
However, if you prefer not to wait, simply clone the read-only script
cp /usr/sbin/vpnrouting.sh /jffs/scripts/vpnrouting.sh
chmod +x /jffs/scripts/vpnrouting.sh
Use nano/WinSCP etc. to edit /jffs/scripts/vpnrouting.sh
Test your script by mapping your modified script to the original
mount -o bind  /jffs/scripts/vpnrouting.sh /usr/sbin/vpnrouting.sh
df
and restarting the VPN Clients to see if the VPN Clients initialise successfully, and to check if the modifications to the RPDB rules has been made; issue:
ip rule
To revert to the original read-only script simply issue:
umount  /usr/sbin/vpnrouting.sh
NOTE: OpenVPN scripts can also be manually specified by the user either in the GUI or even via the openvpn-event trigger scripts but the mount/umount method is 'global' rather than per client.
