AC87U..I can't access Ruttorent WebUI (Entware)
sammarbella
Asuswrt-Merlin 378.55
I can't access Ruttorent WebUI from LAN (192.168.1.1:81/ruttorent) or WAN (myown.no-ip.biz:81/ruttorent)
I installed entware using the easy install script (entware-setup.sh) and Rtorrent using the easy install method:
https://www.hqt.ro/rutorrent-on-asuswrt-router-through-entware/
I see this method is labeled as "Mips only" but i saw some people using it also for ARM Asuswrt routers.
Rtorrent is already running:
ASUSWRT-Merlin RT-AC87U_3.0.0.4 Fri Jul 17 03:17:40 UTC 2015
admin@RT-AC87U:/tmp/home/root#
admin@RT-AC87U:/tmp/home/root# /opt/etc/init.d/S80lighttpd start
Starting lighttpd... already running.
admin@RT-AC87U:/tmp/home/root# /opt/etc/init.d/S85rtorrent start
Starting rtorrent... already running.
I use an USB 3.0 HDD formatted on Ext4.
firewall-start seems correct:
#!/bin/sh
iptables -I INPUT -p tcp --destination-port 81 -j ACCEPT
iptables -I INPUT -p tcp --destination-port 51411 -j ACCEPT
iptables -I INPUT -p udp --destination-port 51411 -j ACCEPT
iptables -I INPUT -p udp --destination-port 51412 -j ACCEPT
Shares of USB are enabled on router.
This is making me crazy! :confused:
I found it!
I had to manually create the download folder (Rutorrent) in the USB HDD labeled "Rutorrent" because it doesn't created before during install.
I guess i didn't provide the right path during Rutorrent install ("mnt/sda1/Rutorrent" instead of "mnt/Rutorrent/Rutorrent").
After i edit and correct the rtorrent.conf file the WebUI launched properly!.
:D
