Ac88u CTF and Port forwarding
Jffyer
Is possible to activate CTF and have port forwarding running? It only open TCP ports not UDP ones.
Because it is not opening ports,
You'll have to be more specific.
and also i found a lot of articles about this
You can find anything on the internet to support any theory, that doesn't necessarily mean it's true. Also, things that once were true (with regards to routers) may no longer be the case because of updated firmware.
Bear in mind that UDP, unlike TCP, is a stateless protocol so it's very difficult to determine at what point the connection is failing.
You can see the currently active port forwarding rules in the router at System Log > Port Forwarding.
