AC88U or AC68U for second router?
unclebuk
I have an AC68U (auto IP connection) as a dedicated VPN router connected to the LAN of an AC88U configured with PPPoE from the ISP modem. I connect devices to the AC68U to take advantage of geo-blocking afforded by use of VPN clients configured on the router. All seems to work ok up to this point. The WAN/IP warning on AC68U has stopped blinking for some reason...unsure why.
Question: which router should be doing what...ie:, should AC68U be connected to the modem or leave as is with AC88U connected to modem?? Are there any significant differences between these two routers that gives an advantage if I modify the configuration and switch the roles of the routers?
Both routers are running on up to date stock Asus firmwares.
I lack expertise in this and unsure how to maximize the set-up.
Thanks in advance for your input, suggestions, etc.
unclebuk
With its much faster CPU, the RT-AC88U is better suited to handle VPN duties.
