AC88U with node bot?
Master3395
Hello,
has anyone tried setting up Asus AC88U, with USB as a daemon, to run a node bot before?
I tried, but it seemed like the latest fork, has issues with the file sharing?
I can create a folder, but not delete any.
Not from the router, and not from windows explorer.
SSH is the only way to edit any files on the USB.
https://store.steampowered.com/app/682130/Discord_Bot_Maker/
It's running Java Script.
NodeJS is apart of it.
You might want to be a bit more specific - depending on background, "node" can mean a lot of different things...
when I see "node bot" - I'm thinking NodeJS and running a bot in that context
That's just the program it self, not my bot.
As the bot is extracted from that, and runs from my start.bat,
But all it does is to run node bot.js
@echo off
echo Starting..
:main
node bot.js
echo Restarting Bot..
goto main
Probably don't want to run this on the router, even as a shared storage drive for discord...
Look at the requirements...
