Access AiCloud via VLC player..
Germain
Hi! I setup AiCloud..and I want to access via Vlc player.. beacause the app of Aicloud used gplayer ($$ ios app)
Its is possible.. what the url to enter fter my url dydns..
Myuser.dyndns.com:8082 I Access to my Aicloud server!
Hi, if you want access to your cloud from internet via VLC, you have few options:
#1. FTP -setup ftp https://your.router.adress/Advanced_AiDisk_ftp.asp
#2. VPN -setup vpn, and you have access to your LAN
#3. Create share link in AiCloud apk or web gui, and paste in VLC
More option is availaible, but start with this 3.. ;)
Wow thanks you!! I have the 2 one.. but.. don’t open in vlc! :/ I enter my ip.. or dyndns.. and never connect! :/
Lol! Work.. tell me jsername password..and nothing after! :( on VLC
ok, this work:
#1. scan local network in vlc and add aicloud to your favorites, do it on local wifi connection. Open and sign on, you should see files on cloud.
#2. turn off your wifi, enable your mobile data connection, and turn on VPN
#3. open VLC again and click to aicloud you add in step one, and voila.. ;)
