@thiggins - Thanks Tim.
@alekdavis - Here's a
less-than 2 minute video explaining PoE in simple terms (FYI, higher-power PoE standards have been released since that video was made, but it's OK to ignore that for the purpose of just understanding the basics). It's important to note PoE can carry power usually up to the maximum distance of a copper ethernet link (100m), provided the cabling is low-enough gauge and high-enough quality. This means you could inject power into the ethernet cable at your wiring closet, then send power+data all the way to the wall jack, and through to the AP over a piece of patch cable -- instead of having to locally power the AP with the injector or AC adapter plugged into the wall nearby.
As for access points, the TP-Link Omada (EAP) series are one option, good for the price, and each comes with a PoE injector included (many APs do not). An EAP225v3 or EAP245 would provide "good enough" connectivity in conjunction with your wireless router, provided you made the SSID(s) and password(s) the same on both AP and router.
That said, purpose built APs are often most beneficial when they're allowed to handle wifi
exclusively (in your case, with wifi disabled on your router, and replaced by another like-model AP). The main reason to do this would be the likelihood of more reliable 2.4 and 5Ghz in general, plus a higher chance of seamless client roaming between APs (provided the client(s) supported it). You'd also get centralized management and more advanced features (VLANs, etc.). If such a setup was of interest, extra cost not withstanding, you'd want to select APs that were
controller-based (controlled by a single software "brain"). TP-Link Omada is one such option, but the controller is discrete, meaning it must run separately from the APs, installed either as software on a server or always-on PC, or as a hardware appliance (the
OC200, ~$80). An even easier option would be an embedded-controller product, where the controller is simply built into each AP's code, such as Cisco CBW. A CBW140AC is about $100-110 each (versus $60 for an Omada EAP225v3), but way simpler to setup and run two or more APs. CBW APs don't come with PoE injectors, though, so you'd have to buy one for each AP (~$20 each), or just get a 5 or 8-port PoE switch ($50-60). All in all, about 1.5 to 2x more costly than Omada, but on the flip side, about that much easier to setup, as well.
Hope you found some of that extra info of use, in case you wanted to go beyond just a standalone AP plus your router for wifi.
