Hello,
I'm trying to add an access point in another area of a building where a network cable has been run. (i do not have access to the main router). This was put there so the user could plug in his laptop via the cable. However, he has a phone that he would like to connect as well via wifi.. (the wifi they are using does not reach to where he is, hence the cable run).
So I set up a basic router TP-Link and turned off DHCP, set the router to a non conflicting IP address out of the main's DHCP range and setup the SSID and password. So my understanding would be that the main router will supply the IP addresses via DHCP through the access point. It will do this but only for one device. If I try to connect a 2nd device via wireless. It sees the access point and asks for password but will not connect.. It will only connect one device. I did try the TP-Link and Rosewill router (be it very cheap ones) and had same results.
From what I've read online, I thought I would be setting it up correctly.. I have done this at home with an ASUS and NETIS router to get rid of dead zones in my home and it works just fine. I can look at those routers to see what devices are connected and I do not have a one device limitation. Is this a limitation caused by the main router or am I not going about it the best way. Any info, link or guidance would be appreciated..
I'm sure this is very basic, but I'm not understanding why I am having a one device limit..
Thanks..
Thanks..
