Hello everyone,
I recently added an access point to my small network. My main router is an AC68 running Merlin 38_2 and my new access point is an N66 also running Merlin 38_2. I have set the ap with common ssid and passwords as the main router for both the 2.4 and 5g, although each band has a different ssid. So far the system is working great, and clients seem to do a good job choosing the better signal to log into. But here are my questions to you:
1) I set the ap up using the ap mode. I wonder if this is the best choice, vs leaving it in the router mode, disabling dhcp, etc. I ask this because in the ap mode I get very little information - I mean in ap mode of course the firmware does not track any traffic data, and really the only way I even know if someone logged onto the ap is by looking at the wireless log. What do you think? Ap mode seems to make the unit fairly "dumb".
2) Regarding IP, i set my 68 so the dhcp range starts at 192.168.1.3. Next I went into the ap and told it not to get an ip, but rather I told it to manually use 192.168.1.2. Was this the best approach, vs telling the ap to automatically get the ip from the 68, and then setting a fixed ip in the 68 for 192.168.1.2 for the ap Mac? Or does it really even matter?
3) Strangely in both the 68 and ap (66) I am seeing an error message over and over in the log that looks like this in the 68:
Jan 18 23:35:07 kernel: br0: received packet on eth1 with own address as source address\
Jan 18 23:42:23 kernel: br0: received packet on eth1 with own address as source address\
Jan 19 01:51:15 kernel: br0: received packet on eth1 with own address as source address\
Jan 19 07:18:55 kernel: br0: received packet on eth1 with own address as source address\
Jan 19 07:43:47 kernel: br0: received packet on eth1 with own address as source address\
Jan 19 07:56:25 kernel: br0: received packet on eth1 with own address as source address\
Jan 19 07:57:03 kernel: br0: received packet on eth2 with own address as source address\
Jan 19 09:39:57 kernel: br0: received packet on eth2 with own address as source address\
Jan 19 13:21:46 kernel: br0: received packet on eth2 with own address as source address\
And this on the 66:
\outl0\strokewidth0 \strokec2 Jan 1 01:16:32 kernel: eth1: received packet with own address as source address\
Jan 1 01:31:46 kernel: eth1: received packet with own address as source address\
Jan 1 03:24:58 kernel: eth1: received packet with own address as source address\
Jan 1 09:08:11 kernel: eth1: received packet with own address as source address\
Jan 1 09:16:06 kernel: eth1: received packet with own address as source address\
Jan 1 09:30:06 kernel: eth1: received packet with own address as source address\
Jan 1 09:35:33 kernel: eth1: received packet with own address as source address\
Jan 1 11:46:04 kernel: eth2: received packet with own address as source address\
Jan 1 11:46:32 kernel: eth1: received packet with own address as source address\
Jan 1 12:18:39 kernel: eth1: received packet with own address as source address\
Jan 1 12:26:37 kernel: eth2: received packet with own address as source address\
Again, both systems with Merlin 38_2. Really this error does not seem to effect anything, even so it's in the log so I'm concerned. Thanks all.
And this on the 66:
