Access to DSL modem
jenom
I have a DSL modem (Thompson ST516) in bridge mode, and router (Asus RT-N66U) does the PPPoE login.
Would like to access modem webpage for line statistics, etc....however no connection.
Found an instruction on DD-WRT how to access modem before the router:
https://wiki.dd-wrt.com/wiki/index.php/Access_To_Modem_Configuration
However, it is written for DD-WRT not ASUSWRT.........different !
Step 1: ifconfig `nvram get wan_ifname` ..........no such thing !
Used " nvram show" command and looked for anything related to "wan" & "ifname"
Found the following:
wan_ifnames=eth0
wan0_pppoe_ifname=ppp0
wan0_gw_ifname=ppp0
wan0_ifname=eth0
Not sure, if I need to use "ppp0" or "eth0" ?
Is there somewhere instruction written for AsusWrt for modem access ?
(I know, in Tomato this option is built into GUI......just need to enter modem address.)
Thanks!
ColinTaylor
Part of the Furniture
What is the exact firmware version you are using? There are some subtle differences between the versions.
ColinTaylor
You would use the value returned by "nvram get wan0_ifname" which is "eth0".
Do you already know the IP address of the modem's web interface? Can you ping it currently?
jenom
modem has 192.168.1.254 or 10.0.0.138 address
modem is in BRIDGE mode
it is reachable when DIRECTLY plug PC into modem's port
however, it is not reachable through router........that is the goal of this project !
ColinTaylor
What does your routing table look like? (System Log - Routing Table)
jenom
I have not altered there anything:
IPv4 Routing table
Destination
Gateway Genmask Flags Metric Ref Use Iface
206.80.253.242 * 255.255.255.255 UH 0 0 0 WAN
192.168.1.0 * 255.255.255.0 U 0 0 0 LAN
169.254.0.0 * 255.255.0.0 U 0 0 0 MAN
default 206.80.253.242 0.0.0.0 UG 0 0 0 WAN
ColinTaylor
Can you SSH into the router and post the output from this command please:
netstat -rn
Try issuing this command and seeing if you can then ping the modem from the router's command line.
ifconfig $(nvram get wan0_ifname):0 10.0.0.2 netmask 255.255.255.0
ping 10.0.0.138
jenom
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
206.80.253.242 0.0.0.0 255.255.255.255 UH 0 0 0 ppp0
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 br0
169.254.0.0 0.0.0.0 255.255.0.0 U 0 0 0 eth0
127.0.0.0 0.0.0.0 255.0.0.0 U 0 0 0 lo
0.0.0.0 206.80.253.242 0.0.0.0 UG 0 0 0 ppp0
jenom
that worked
[email protected]:/tmp/home/root# ifconfig $(nvram get wan0_ifname):0 10.0.0.2 netmask 255.255.255.0
[email protected]:/tmp/home/root# ping 10.0.0.138
PING 10.0.0.138 (10.0.0.138): 56 data bytes
64 bytes from 10.0.0.138: seq=0 ttl=64 time=20.569 ms
64 bytes from 10.0.0.138: seq=1 ttl=64 time=0.829 ms
64 bytes from 10.0.0.138: seq=2 ttl=64 time=0.833 ms
64 bytes from 10.0.0.138: seq=3 ttl=64 time=0.797 ms
64 bytes from 10.0.0.138: seq=4 ttl=64 time=0.795 ms
64 bytes from 10.0.0.138: seq=5 ttl=64 time=0.810 ms
64 bytes from 10.0.0.138: seq=6 ttl=64 time=0.989 ms
64 bytes from 10.0.0.138: seq=7 ttl=64 time=0.805 ms
--- 10.0.0.138 ping statistics ---
8 packets transmitted, 8 packets received, 0% packet loss
round-trip min/avg/max = 0.795/3.303/20.569 ms
ColinTaylor
Now check whether you can do the same ping from a client PC on your LAN.
heysoundude
I have that exact modem.
Thomson was acquired by Technicolor, and some of this older equipment ceased to be supported.
My ISP gave up on helping me configure it (it was on their “approved hardware” list) and sent me one of their modem/routers.
jenom
now I can reach router website :)
does this setting gets last when reboot ?
if yes, how can I make it permanent or start automatically ?
thanks
ColinTaylor
thanks
To make it permanent you need to create a user script containing that command. Probably the most appropriate script would be wan-start, but you might have to put a "sleep 20" before it to ensure the interface has fully come up first (see this thread). There doesn't seem to be any need to do the POSTROUTING change.
jenom
to heysoundude
I know that ST516 is old technology from 2007-2008-2009, it is an ADSL2+ modem, works perfectly on a my 15 MB/ 1 MB DSL phone line......supposed to be good upto 25MB/2MB
Configuring was just few easy steps:
1)login to webpage
2)select "bridge"
3)choose VPI/VCI 0/35 (Bell Canada)
4)choose DHCP enabled/disabled
5)save
6)reboot
and let the Asus RT-N66 handle PPPoE login + routing
heysoundude
to heysoundude
As long as you know that for faster uploads, you’ll need a different modem. In my case it may have been an actual problem with the hardware, or the CSR knew my ISP was giving modem/routers away with new activations that were pre-configured.
jenom
my household is 2 adults, 2 x wifi routers, 2 x voip , no streaming >>>>15Mb/1MB unlimited good enough.
I prefer to choose ISPs which allows BYOD,specially in case of DSL service.....and always used "bridge" mode.
