1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. SNBForums Code of Conduct
    Dismiss Notice
Dismiss Notice
Welcome To SNBForums
Access to PC connected to bridge WiFi
Discussion in 'General Wireless Discussion' started by Jorgensen, Jul 8, 2019.
Tags:
  1. Jorgensen
    Jorgensen Occasional Visitor
    Oct 17, 2018
    11
    I have just completed the following setup:
    Fiber modem -> Cable -> Asus AC68U -> WiFi 2.4 GHz ->Asus AC66U_B1 -> Cable -> MediaCenter
    My media center only supports cabled network connections, thus I purchased a 2nd Asus router to act as a media bridge. My problem is now that I can't connect to the MediaCenter from a laptop which connects via WiFi to the Asus AC68U (primary router). I can ping the media center, RTT is 2 ms, but when I type in the IP address of the media center in Putty and connects, I just receive the error messages: Connection refused.
    The media bridge router is using default (media bridge) configuration. Do I need to setup NAT on the media bridge router? Or do you have other suggestions to solve this problem?
    Thanks in advance,
    Jorgensen
  2. Jorgensen
    Oct 17, 2018
    11
    After rebooting both routers and the MediaCenter I have now gained access to the MediaCenter :)
