access usb drive from Aimesh Node
Sam Lee
I've put the usb drive to the Aimesh Node router but now I cannot access it. I can see it from my network but when I try to open one of the shared folder, it prompts for username & password, I've tried using the one from my main router or even the default password but nothing works so far, anyone have any suggestions? I could put this on my main but it is sitting up the attic so I prefer to have the drive within range. TIA.
Anyone know the user name & password for the Aimesh Node router? I've already tried the default uid/psswd, nothing seems to work.
All AiMesh node reset back to factory default before connect to AiMesh primary router, user/pass will be back to default admin/admin.
Its not working - the same in my situation, I can see in network in windows, unable connect wrong password and user name.
By the way - node was reset prior to access to mesh system so if I reset again I need to add again back
