Accessing clients by hostname not working
bilged
I'm not sure if I'm doing this right at all - any tips would be greatly appreciated. On my router I set up a hostname and domain like: router and mydomain.internal. From a client PC I can ping either router or router.mydomain.internal successfully. Under LAN > DHCP server I can add clients on my network by name from the dropdown so the router is definitely recognizing them. I can also ping any client by IP address. However, I cannot ping by client hostname like ping mypc.mydomain.internal. Is there some additional step needed for this to work? Thanks!
Firmware is 386.7_2 on RT-AC68P
nslookup mypc.mydomain.internal
Server: 127.0.0.53
Address: 127.0.0.53#53
** server can't find mypc.mydomain.internal: NXDOMAIN
If I look at /etc/resolv.conf it has:
nameserver 127.0.0.53
options edns0 trust-ad
search mydomain.internal
and under /run/systemd/resolve/resolv.conf
it has
nameserver 192.168.0.1
That looks correct (router IP and domain).
Edit: I think I figured it out. Seems like its an issue with Ubuntu. I did the below from the client which fixed it...
sudo rm -f /etc/resolv.conf
sudo ln -s /run/systemd/resolve/resolv.conf /etc/resolv.conf
Taken from the top answer here...
It seems this has been an issue for a while. Strange that ubuntu has it set up this way.
