Accessing FTP site using External IP Address, blocking
Mark070
Hey there,
Configuring my Dream Machine, and I have a FTP server sitting behind the firewall, address 192.168.1.5 port 6032 (SFTP).
I added a Port Forwarding rule that maps to that, and thats all I have done in terms of the firewall/port fowarding.
When I try to access the FTP server using my external ip address (example. 66.100.56.120:6032) from something like Filezilla, it's blocked by my firewall.
I can ping that address (minus the port) and that works fine. I can use my internal address and that works fine. I just cannot connect using the external IP address.
Is there something I missed? my firewall rules messed up? (attached picture of rules). Keep in mind, these are the default rules, only one added is the port forwarding.
My EdgeRouter 4 works just fine, but the Dream Machine (defaulted state) does not seem to like it
Thanks for any advice in advance
FTP and SFTP are different protocols that use different ports. I can't see from your screenshots what ports you are forwarding, and you haven't shown us the FileZilla connection details.
Correct, I have setup SFTP (port 6032) on my internal server. (attached picture). This has not changed, and works just fine.
I have also attached the Port Forward Rule as well
Good to see someone using a Dream Machine.
Any chance you need to add an ACL or port forward rule for your outside IP addresss? I would try it just to make sure it does not change things.
Any should cover it. Maybe a public IP is not allowed.
The port forwarding looks correct. We can see the client connects to the server but it isn't doing the key exchange.
I would look at the logs on the server machine. I suspect it's a configuration issue with the SSH server. Sorry, I can't offer any other ideas as I don't use the same devices as you.
Turns out, I believe, as I have the FTP server down right now; the current stable UDM firmware has an issue with Hairpinning/loopback Nat (?) when the IP Address is 192.168.1.1. They have a fix in a newer RC version of the framework. In the meantime, I moved my network to the 192.168.10.1 address. That seems to allow me to use the external address.
Thanks for the help.
S Problems accessing home network from external networks. Other LAN and WAN 8
