Accessing NAS from internet issues
flowrider
I know that many of you don't think that allowing access to your NAS is a good idea from the internet but help me out anyhow!!
I have a new Asustor 304T NAS that I'm trying to setup. They have a utility called EZ-router which is supposed to help you route traffic from the internet to the NAS. Anyhow I'm getting a double NAT I think. Here's a screenshot of the error I'm receiving.
My setup is as follows:
Actiontec 1200H modem/router bridged on LAN port 1
LAN 1 to Asus AC68 WAN running OpenVPN. Lan port to switch.
NAS connected to switch.
Anyway I'm not too sure how to fix this. My networking skills are rudimentary at best. If anyone can give me a suggestion so that I can fudge around and try and fix this it would be appreciated.
Steve
Is the router/modem in PPPoE bridge mode, if your modem uses that mode from the DSL company?
I have no idea Joe. It is the modem from the DSL company. I'm amazed that they switched me to this modem/router as it is where I could bridge one LAN port. I'll have a look again but it's literally one radio button and it's done.
Sounds like the Actiontec isn't really bridged. If you can access its admin, check it out
According to the menus I am in bridge mode. Here's some screens of my modem setup.
I have IPTV so I wasn't sure I I could change my setting to PPPoE. Is there a way to check to see if I'm truly bridges or not? I don't want to bridge the AC68 because it's running Openvpn.
ASUSTOR's EZ-Router function appears to be trying to use UPnP to open router ports [article]. So make sure UPnP is enabled on the ASUS router. If it still doesn't work, open the required ports manually.
If that still doesn't work, then something is off in the Actiontec bridge implementation.
You could try putting the ASUS WAN port IP address in the Actiontec's DMZ. This doesn't reduce your security since the ASUS' firewall is protecting your LAN (except for the ports you open to the ASUSTOR). And if the Actiontec were really bridged, all ports would be open to the ASUS anyway.
I just checked and I think I'm checking the correct tab but it's enabled. I'm not too sure what ports I'm supposed to open though.
I also tried to add the routers Wan address to the router/modem but it wouldn't take it saying that that it was an invalid IP
If the ASUS WAN IP is a public routable IP, it means that the Actiontec is bridged.
I agree UPnP looks enabled in the ASUS. So open the ports manually. The ports you open depend on the services you are trying to access. Look at the ports in the linked EZ-Router article for a start.
Remember, common service ports like 80, 8080, 443, etc. will be found within minutes, if not seconds. Make sure you have a damned strong password for the NAS itself and all shares.
Thanks Tim. Ok so on a lark I disabled my OpenVPN client for Private Internet Access and disabled it. EZ-router now connects fine. I want to be able to run both services. Not too sure where to go from here.
Well THAT certainly makes a difference!
Why not just access your NAS through VPN?
How are you checking access from the Internet?
Okay so an update.
If I disable the OpenVPN client all seems to work. I'm using Merlins newest firmware so what I've done is created a Policy rule for my 2 Apple TV's and main desktop to route through the VPN tunnel. That all seems to work. When I check EZ-router now, some services seem to work (WebDAV) but some don't (FTP, Web Service, etc). I didn't think about access the NAS through VPN if I get you correctly. Are you saying setup a VPN server on the router and go in through that? I'll give that a try. My only issue with that is I don't think I can get through when I'm at work since I'm behind a proxy (or at least it didn't work the last time I tried it).
I'd not want to open NAS access to the Internet without at least SSL or VPN, probably the former. Then you have the hassle of getting a certificate, etc.
Synology and QNAP and (who else?) have SSL-only access as an option.
I have opened a router port to do so, on rare occasion. (I do NOT enable uPNP in my LAN!). I sometimes open ports for the NAS, but only for a short duration. Just too many scanners out there and they know the port numbers often used by NASes and they even know vulnerabilities of the Linux versions used by each OS release from NAS vendors.
I wouldn't open a NAS box to the internet, just too risky... again, I'm also a person that strongly recommends not putting USB drives on router/AP's...
And like Stevech, I'm not a big fan of uPNP/NAT-PMP - so I disable it, and only open up ports on an as-needed basis...
Thanks for your help everyone. I ended up using selective routing on the AC68 and it works fine. OpenVPN and Private Internet Access was blocking any access to the NAS. I'll see how much I actually need to access the NAS through the net then decide whether to block it or not. Some very compelling reasons why to close it off or not.
