Diversion Ad Block SHIELD Apps?
  • ATTENTION! You'll notice a Prefix dropdown when you create a thread. If your post applies to one of the topics listed, please use that Prefix for your post. When browsing the thread list you can use the Prefix to filter the view.
OmniiOMEGA
Hi there,
Is it possible to block ads on NVIDIA SHIELD or iPhone apps?
I’ve managed to setup diversion stock standard and so far it’s blocking ads on our Hisense Smart TV 10Play App?
PeterR
If ads are blocked on some devices and not others, the first step would be to check the device settings to see which DNS server it's using, it should be your router's ip addresses. Also check on the router that on the LAN|DNS Filter page you've set 'Enable DNS-based Filtering' to ON.
OmniiOMEGA
Thanks @PeterR I've switched that on and turned Global Filter Mode to Router. What Custom DNS settings should I use, what if I specify Client List?
