AsusUser999
I just got the RT-BE86U and I couldn't add networks after the initial setup process. The "Add a Network" buttons in the Network section of the firmware didn't work.
In Main Network, it came up with a message saying the rules were at maximum and in Guest Network Pro the button did nothing at all. I'd created an IoT network in setup, so I deleted that to free up some space and... still it wouldn't create a new one.
So I switch to Merlin (I did a reset to factory after flashing it, as recommended to get rid of any excess rules)... and it was the same. Slightly different message "Your rules have reached the maximum".
I looked at each of the rules that were exposed by Merlin and I had 1 DHCP rule and 0 in any other section. Then I ran iptables -L -v -n and iptables -t nat -L -v -n via SSH and it came up with a lot of rules but nothing that looked like a hangover for guest/IoT networks etc.
Then I found that I could create a new network using the preset types on the right side of the Network area (Guest Network, Kids Network, MLO Network etc). All these seem to be guest-type networks though, not Main ones.
Strange... so I asked the AI about it and it suggested it's a fw bug. It seems strange to me that an obvious bug like that wouldn't be spotted and fixed by now though? So I searched the forums here - nothing. And now, as a last resort, I'm posting this to see if anyone else has come across this. Thanks in advance.
P.S. I'm considering swapping it for the later RT-BE92U which apparently has fewer bugs. I bought the 86U for its CPU power for encryption but on a 250Mbps connection the 92U may have enough grunt? We don't have any Wifi6E or 7 devices yet, so the 6G channels would be unused and we'd have fewer 5G channels with the 92U... I have a couple of weeks to decide before the return window closes on the 86U. I do use 2 older XD4N nodes for aimesh with wired backhaul, which seem fine with the 86U and should be even better with the 92U, so I'm torn. Any input appreciated.
