Add on for RT-AX3000
TheAstronautGardner
I have an RT-AX3000 running for wired and wireless connections. It works great, but I need to extend its reach. Is the best bet to get another RT-AX3000 and connect it via ethernet and use it as an access point? Is there another device I should consider? I'd love a wireless option, but I don't think think they will carry the signal well enough. Any help is appreciated!
L&LD
Part of the Furniture
Welcome to the forums @TheAstronautGardner.
With an identical router, running identical firmware (and all having been fully reset after flashing the firmware you want to use), I've noticed much more stable networks. Wired backhaul is always preferred, but don't forget you can also use AiMesh mode too to extend not only the main network, but also the Guest Network 1 too.
