Adding additional USB wifi radios
ReaverRui
Perhaps this is more a feature request, but as it is my understanding, the firmware is built upon OpenWrt/Linux (for which drivers are available). Would it be possible to add an additional WIFI radio via USB stick to AsusWrt-Merlin? I know it gets a little complex because you have to consider a plethora of chipsets (not to mention performance probably not great) but if there was some way for a user to install the specific driver and then it loads an GUI for setting and connection stats monitoring. Otherwise you could make settings changes via command-line.
I have a RT-AC68U and do VR/tablet gaming streaming, but i would like to limit the 5GHz AC connection to 1 stream device at a time, but still have other devices, on 5GHz N network, which i have a stick for.
AsusWRT is not based on OpenWRT - it's more related to Tomato and DD-WRT, but that fork happened a long time ago.
Moderm AssuWRT builds on the chipset SDK/HDK's - Broadcom's HND platform for most of the modern Asus routers..
You might want consider some of the newer tri-radio models - you could set up and dedicate an SSID for your purposes..
