No add on exists. But you can do it manually by editing the file /jffs/configs/dnsmasq.conf.add.Hi all,
Quick question: Is there a way to or an add-on that allows for adding custom dns entries (dnsmasq) via the UI?
Thanks.
[Release] Asuswrt-Merlin 384.11 is available
I am happy to see again all the devices connected to my network! since 384-08 I can see them againwww.snbforums.com
If you go this route, be sure to disable the Asus web UI Manual Assignment in the LAN settings area after you have created dnsmasq.conf.addDhcpStaticList
I’m not entirely sure my script is running dhcpstaticlist.sh how can I check? be easy on me, I’m not that familiar with Lunix Running 384.19 I have endeared running with spdmerlin and ntpmerlin. should there be a start up in services-start file of /JFFS/scripts?www.snbforums.com
Welcome To SNBForums
