Solved Adding own SSL certificate
original-birdman
I'd like to upload my own SSL certificate (I have my own root CA for some local systems, and it's installed in my browser) so that I don't need to keep allowing exceptions every time the router-generated certificate changes.
However, there is no indication as to what format this needs to be in in order for the upload to work. (WAN -> DDNS tab, HTTPS/SSL Certificate, Import Your Own Certificate).
Does anyone know? Or where the files lives on the file-system after the upload (so I could just copy it there directly)?
Standard PEM.
OK. Found this in syslog, which may explain why it isn't working:
Jun 29 23:31:26 httpd: Can't get subject/authority key identifier. ([20:F8:7B:6]/[NULL])
Jun 29 23:31:26 httpd: Delete uploaded certificate
Jun 29 23:31:35 httpd: Can't get subject/authority key identifier. ([20:F8:7B:6]/[NULL])
Jun 29 23:31:35 httpd: Delete uploaded certificate
Not sure what the problem is. Apache is happy with similar certificates (for different hostnames)
OK. Sorted it.
I needed to tick another box when generating the certificate (and then had to generate it again to add IP address fields as well as DNS names...).
Thanks...
What box did you need to tick? I can't make it work either.
Well, I suspect that depends on what you are using to generate them.
I'm using xca, and under the "Extensions" tab I had to select the "X509 Authority Key Identifier" option.
Given that the Validation tab when looking at a Certificate's details was pointing out that this was missing, I'm not sure how I'd missed it for several years.
I'm using .net. Several years ago, when Asus changed their certificate policy, I tried to make it work but failed miserably with the message, you also got. I ended giving up.
But your question and answer got me in the right direction. The key was indeed to implement "X509 Authority Key Identifier". Not easy at all, but now I got it working with my own CA, thanks for your help.
