Hi there. I currently have a two-node setup with a couple of Asus Zenwifi XT8s connected by wireless backhaul.
What I'd like to do is extend wifi coverage to my detached garage, which is about 100m from my house, so that I can install some IoT devices (light bulbs, camera, garage door opener, etc.)
Currently, the mesh network doesn't reach the garage at all and I believe this is because the router is on the far side of the house, and the node is in the basement hooked up to various IoT hubs. I'm trying to find out that if I purchase an XD4 or even a CD6 node and place it near a window on the first floor that has line of sight with the garage whether this would help? I think it would be overkill to get another XT8 for this purpose as the coverage within the house works great.
Anyone with a similar experience (doesn't even have to be with the Asus gear) able to share any info? Unfortunately, it's not possible to run cable between the house and garage because it crosses into common property.
