Suricata Addon-Tabs are not loaded
here1310
AX88U- Addon error
"/jffs/addons/suricata/suricata_stats.sh startup # Suricata_Stats.sh" in post-mount script prevents loading of the other addon tabs
/jffs/scripts/dn-vnstat startup "$@" & # dn-vnstat
/jffs/scripts/spdmerlin startup "$@" & # spdMerlin
/jffs/scripts/connmon startup "$@" & # connmon
/jffs/scripts/ntpmerlin startup "$@" & # ntpMerlin
/jffs/scripts/uiScribe startup "$@" & # uiScribe
/jffs/scripts/uiDivStats startup "$@" & # uiDivStats
/jffs/scripts/scmerlin startup "$@" & # scMerlin
#/jffs/addons/suricata/suricata_stats.sh startup # Suricata_Stats.sh
sleep 30
/jffs/addons/unbound/unbound_stats.sh startup "$@" & # Unbound_Stats.sh
If you remove suricata_stats.sh all tabs are loaded without only the suricata tab being loaded....
the sleep 30 before and unbound_stats.sh at the end I set because unbound_stats.sh also prevents the other tabs from being loaded....
i found in suricata_stats.sh: (??) share: /jffs/addons/shared-jy is not exist
#needed for shared jy graph files from @JackYaz
readonly SHARED_DIR="/jffs/addons/shared-jy"
readonly SHARED_REPO="https://raw.githubusercontent.com/jackyaz/shared-jy/master"
readonly SHARED_WEB_DIR="$SCRIPT_WEBPAGE_DIR/shared-jy
I have a AX88U, installed this program, I have the tab on the add-on page
thanks for the feedback.
1. if only suricata is installed, it works.
2. if other scripts, like ntpmerlin etc. are also installed, only! the suricate addon will be loaded, the others not
3. without suricata the other addons are loaded, see # in post-mount
after much trying...in the order (post-mount) it works....
/jffs/addons/wireguard/wg_manager.sh init "" & # WireGuard Manager
#sleep 30
