Adventures in random: Nanoseconds
smasher
I was experimenting with the nanosecond counter (/proc/timer_list) from which nanoseconds can be derived by this:
awk 'NR==3 {print $3}' /proc/timer_list | egrep -o '.{9}$'
After millions of tests, in loops with various delays, the 3rd digit in that string (millisecond; one thousandths of a second) always showed a strong bias towards 6 and 7, away from 0. That bias was observed as strong as 3.989:1 in a test with over 3 million samples, and random delays in the loop of 0-100ms.
Here's output of "ent -c", looking only at the milliseconds in that test:
** Colum 3 :
Value Char Occurrences Fraction
 48   0       149132   0.047788
 49   1       203716   0.065279
 50   2       224348   0.071890
 51   3       250520   0.080276
 52   4       269017   0.086204
 53   5       328622   0.105303
 54   6       594926   0.190638
 55   7       566125   0.181409
 56   8       290911   0.093219
 57   9       243400   0.077995
Total:       3120717   1.000000
Entropy = 3.187371 bits per byte.
Optimum compression would reduce the size
of this 3120717 byte file by 60 percent.
Chi square distribution for 3120717 samples is 93308622.59, and randomly
would exceed this value less than 0.01 percent of the times.
Arithmetic mean value of data bytes is 53.1826 (127.5 = random).
Monte Carlo value for Pi is 4.000000000 (error 27.32 percent).
Serial correlation coefficient is -0.029210 (totally uncorrelated = 0.0).
nb, the statistics reported above reflect a comparison with an input of raw bytes, not decimal numbers. Ideally, a random set of decimal numbers, of the same size, should look more like this:
 48   0       312072   0.100000
 49   1       312072   0.100000
 50   2       312072   0.100000
 51   3       312072   0.100000
 52   4       312072   0.100000
 53   5       312072   0.100000
 54   6       312072   0.100000
 55   7       312071   0.100000
 56   8       312071   0.100000
 57   9       312071   0.100000
Entropy = 3.321928 bits per byte.
of this 3120717 byte file by 58 percent.
Chi square distribution for 3120717 samples is 76769638.20, and randomly
Arithmetic mean value of data bytes is 52.5000 (127.5 = random).
Serial correlation coefficient is 0.000000 (totally uncorrelated = 0.0).
In testing, the ten-thousandths of a second showed a weaker bias, which continued through to about the microsecond range. The least significant digit (nanoseconds) showed no bias.
I saw similar biases in the milliseconds with delays in the loop ranging from zero (full speed) to 0-1000ms random delays. I didn't test with delays longer than 1000ms, because it would take ridiculously long to gather a large enough data-set to run meaningful tests.
This got me thinking about ways to generate random numbers (and random strings) on this device, and in the near future I'll post a shell-script that I'm very happy with.
Based on my observations, deriving random numbers from the nanosecond counter is not best practice, on these devices.
RT-AC68U
Merlin 384.13
D Random timeouts on Firmware:3004.388.8_4 Asuswrt-Merlin 6
