Advice for VDSL Modem...
Gamexland
I have TP-Link w9960 but It's very simple... I saw some ASUS VDSL Modem with Stability Adjustment function and more.. those Functions are Good for me.
I need a VDSL Modem with High End and Professional Features. Wifi is not important for me... I have alot of Router with 5Ghz and good functions so Any VDSL Modem without wifi is welcome.
Any Suggest?
You can't fix bad xDSL connections with a modem, if that's the goal. TP-Link modems are simple, but reliable. Buying something much more expensive doesn't guarantee you better connection. No matter what features your modem has, the line will work the way it was set by your ISP provider.
