Advice on inexpensive extender for Asus RT AX-86U system
MartinF
I have a 2000 sq ft home, with an Asus RT AX-86U downstairs. I have 400+ mbps internet, and pretty good reception everywhere except one bedroom, where the signal often drops so low my phone will switch to cellular. Running a cable is not something I know how to do, at least not in a way that would pass the wife test.
There is a spot at the top of the stairs near this bedroom that may be usable for a small router/repeater, preferable one that would hug the wall, as there isn't a lot of space where it's not in the way. It's not a critical spot, so I can handle reduced speeds, even half. Mainly I want to avoid switching to cellular, as I have a limited data plan.
I could buy a mesh system, but I like the Asus/Merlin setup, and would like to try their aimesh. I don't want to invest too much in my current setup, which is dual band. Perhaps in the future I'd want to go tri-band for better performance, but I don't really know much about this. And I don't want to spend too much time learning right now, as I just moved and everything is a mess that needs my attention more than this.
Can anyone recommend a temporary solution for now? Like an inexpensive aimesh-compatible router.
Good shout. Was using one before the switch to Ubiquiti. Worked well.
Little off topic, when I first set the Ubiquiti stuff up, I had left the RP-AX58 connected to the network and the Unifi OS was seeing it as a totally different model.
Hi. Can someone explain how works exterder? Why we need extender and not a cheaper router? Why people buy two routers and making AiMesh system instead of buying cheaper range extender and then making AiMesh? Thanks.
Because AiMesh is genius marketing strategy and what it does best is selling more "routers" to existing customers when needed or not. The presentation page looks pretty and contains the modern key words "AI, mesh, powerful, professional, seamless, easy" - if you know nothing better it seems the perfect choice. The reality - there is nothing AI there, often it's not even a Mesh, compatibility is a mess and performance is on good luck. Most people on SNB Forums buy Asus routers just because of Asuswrt-Merlin firmware.
