Affordable PoE+ splitter
m_a_c_e
I can find relatively inexpensive PoE 802.3af splitters ($15-$20, TP-link, Trendnet). However, the few PoE+ splitters I have found are 5-6X the price. Can someone suggest a good PoE+ splitter?
Thanks,
Mace
Thanks,
Mace
What are you trying to accomplish? Are you trying to power multiple devices using one power source?
I use POE for a couple of applications but POE & Splitter aren't ringing any bells for me.
Is what you're powering needing poe+ wattage? Because if not you can use a regular poe splitter. The two standards are supposed to work together.
T POE vs plug power adpaters Switches, NICs and cabling 7
