After Firmware Upgrade, can no longer find Guest Network
Davidncali001
So I updated my firmware of my RT-AX86U Pro with RT-AX86U_PRO_3006_102.4_beta3 . I updated before I read the Changelog and now I notice my orignal Guest Network completely disapeared and was replaced with Guest Network Pro.
My problem is the original Guest Network although missing and no longer accessable from the GUI it is still giving off a singal and my IOT device is still connected to it and working. I want to switch to Guest Network Pro but I need to remove the old Guest Network config somehow.
I kind of figured a complete reset might be the solution. Is there anything I can try by SSH into the router and manually removing the old Guest Network configuration?
I ended up reverted back to the older firmware and then disabling the guest network then. After that I reinstalled the latest firmware and now Guest Network Pro works correctly.
