Ai Mesh ssid's issue
RaveBoy
Long story short, for sure I'm doing something wrong.
Current setup:
AXE16000 as main router
- 5ghz-2 disabled
- 6ghz disabled
Ai mesh node AX86U
2ghz wifi name: Vector2G
5ghz wifi name: Vector5G
when adding the AX86U as a node, in aimesh page under node network is broadcasting Vector2G for both 2ghz and 5ghz.
For 1 month it worked, now at a restart it's not working.
Troubleshooting steps:
- hard reseted both routers
- did all possible combinations of firmware merlin and stock
All with the same result.
Any idea what I could do more ?
Do you have SmartConnect enabled? Disable it.
Did you perform a full reset after flashing the firmware you wanted to use/test? A full reset before does nothing. Same as using any saved backup config file to configure the router after doing a full reset.
Sorry to jump on this thread...
I understand the backup config possible issues after a reset... But can I use YazDHCP to restore the DHCP without no issue? Thanks
Without issues? I don't know. I wouldn't.
If you formatted the USB drive in a PC as NTFS (after saving the YazDHCP backup file) before putting it back into the fully restored router (and then using amtm to format it to Ext4 with journalling...), I would say it has a better chance of 'no issues'.
Depends on how 'clean' your full reset is.
I would add YazDHCP (and all other scripts) last.
