AI Protection - Malicious Site Blocking
dieter
AI Protection's "Event Details" lists entries from my WAN port to primarily Pixel.Bilinmedia.net. (see attached JPG)
Does this mean one of the clients on my LAN is trying to go to Pixel.Bilinmedia.net?
I can't find anything on this URL.
Equinox
I had the same issue. To solve this , update your Windows host file. There is a good template that you can use: http://someonewhocares.org/hosts/
RMerlin
Asuswrt-Merlin dev
I would check that DK Tablet, might be a malicious application installed.
dieter
DK tablet is my Android Samsung tablet. It caused most of my AiProtection security events.
Does Android support a "hosts" file. Or how do I stop these events?
RMerlin
Asuswrt-Merlin dev
You need to track down the source rather than just hide it. Review every installed applications on that tablet, one of them might be malicious. You will need to uninstall that application.
Equinox
Not sure about Android OS.
Two my desktops had the same issue. It was caused by accessing particular website. After updating Windows host files, the issue went away.
dieter
What are "Two-Way IPS" events?
Most event sources are from my Roku device going to Roku, Inc. (Cross Site Scripting - XSS events.) I'm also seeing several "External Attacks".
If I were NOT using AI Protection, would these events cause any issues?
eastavin
madfusker
I am getting it from multiple devices on my network too. I am suspecting a popup from some site. AI emails me a few times a day with this and would be good to just block it on the router. Any suggestions on how to do that?
Event number : 1
Alert type : Malicious Sites Blocking
Source : (50:85:C5:0C:2D:C0)
Destination : pixel.bilinmedia.net
vanic
You find this mail, it means the URL access is blocked by AiProtection already.
