AiCLoud and dnsomatic
wbennett77
I am trying to get AiCloud to work using OpenDNS and dnsomatic. It all seems so simple except that once I turn on AiCloud the link that it shows to click on is not valid (all.dnsomatic.com). Does anyone have this working with OpenDNS and dnsomatic? If so, how did you get the connection to work? The message I am getting is "You tried to visit all.dnsomatic.com, which is not loading.You tried to visit all.dnsomatic.com, which is not loading."
Cheers!
Yes is working with OpenDNS and dns 0 matic. Follow the link: http://forums.smallnetbuilder.com/showthread.php?p=110318.
You have to download the binar package, put it in jffs/scripts folder and run it manualy once to provide: user, pw & host.
From the AiCloud app (android & IOS) configure pe router address with provided to you by duia.eu. You will need it only when you access the AiCloud.
A bonus: if your ISP is offering you IPv6 you will have IPv6 in your LAN for 3 hosts.
Hope it helped! :-)
Cheers!
dnsomatic is a meta DDNS, meaning that the router has no idea of what actual DDNS you have configured on dnsomatic's website. You will have to manually type the correct address based on which DDNS service you configured on the DNS-o-Matic website.
