Ive been running an rt-ac86u on Merlin firmware 386.3_2 for some time. In addition I have a couple of rt-ac68u as aimesh nodes (running same Merlin firmware version no ) and recently come into some issues where periodically can't connect to the admin console. My current setup is rather basic with a VPN server and one client configured. The only addin I have currently enabled is nsru.
In trying to trouble shoot I have reset (and initialised) the router and flash the standard Asus firmware to each node and re-added. I also used nsru to add back my config, but not the jffs partition.. on restart everything works perfectly, until I tried to setup the guest WiFi.
Whilst the guest WiFi works and is pushed to the nodes correctly, as soon as I enable access intranet = false, I can now longer access the router admin console. The internet still works as does SSH, but I lose access to the GUI console.
I fully accept this could possibly an issue in restoring a backup using the nsru config or more probably a lack in my understanding but does anyone know what could be causing the issue before I try the reset again without the restore..
Thanks for any help offered..
