Part 1:
Adding a second as a node. I factory reset an old and proven RT-AX86U which had Merlin code and add it as a node. Within minutes I notice some of my IOT devices dropping and connecting again and again. I recall seeing others with similar complaints about IOT devices dropping. I turn off the node and they stay connected. I turn it back on and they start dropping. I connect my phone to the node and speed is terrible. I bring the node near the router and ethernet connect it. Connect my phone to it and communication is great. As signal was reported great in the nodes original position, I did not think it was a WiFi signal issue yet tried a much closer position and still bad speed with WiFi 5-Ghz backhaul. I load Asus firmware on the RT-AX86U node with the router RT-AX86U on Merlin. Place the node where it original was tried and it works great! There appears to be an issue with Merlin 386.5_2 on a RT-AX86U running as a node and RT-AX86U running the same version of Merlin. Asus 3.0.0.4.386.46061 works fine on the same node with Merlin 386.5_2 on the router.
Part 2:
I've been running on a single RT-AX86U since my node died mid fall. The node was used to cover my back yard as the router covers our home. With warmer weather we have been using our outdoors areas again and the outdoor WiFi has been sub par. I purchased a pair of XD6 connected them up and all was good though one of the two XD6 took a few tries to bring up to firmware rev. The code's checksum was good and after the upgrades everything ran great for 12 hours. Then the router (RT-AX86U) started crashing about every 15 minutes. As things had been stable to 12 hours I suspected the router and replaced it with a brand new RT-AX86U with Merlin. Crashes continued leaving me scratching my head as the router had been running great with the past few revs of Merlin. I talked with my wife, a very experienced computer tech and she asked "What changed?". I replied, "I added the XD6 nodes yet it ran great for 12 hours. You are asking the correct question so I'm powering them down." 30 minutes later no crashes and I complemented my wife. I waited 3 hours and then suspected the XD6 with the difficult firmware upgrade. I powered on the other XD6 and everything continued to run fine. 3 hours later I powered up the questionable XD6 node and 12 minutes later the router rebooted. I wondered if the node has a bad firmware load so reset to factory, went through a setup and loaded the firmware via an ethernet connection. It seemed good. Factory reset, joined to AiMesh and instant router crash. I'm returning the XD6 pair.
AiMesh seems rather sensitive and I'm surprised with it's age. I plan to add a single XD6 as a second node with one RT-AX86U as node and another as a node. This provides a quick switch for our main router should it develop an issue.
Part 2:
