jeffll
I have three RT-AC88U routers. One I have setup in AP mode on my own network (since Google Fiber requires using their own router). Another I have setup as the router at my parents' home. The third I just bought to add as an AiMesh node to my parents' network (so as to extend the Wi-Fi coverage out by their pool).
I live in a different state, so I had the new router shipped to my home, where I set it up and tested the AiMesh setup process on my own network. It worked great. The process was quick and easy. I reset the node by disconnecting it from my router in the settings. I performed a final search to find the node again, but didn't add it, just to be certain it was still setup in the right mode to make it easy to find, so the process would be as smooth as possible to set it up remotely with my Dad.
But then when my Dad hooked it up at his house, I performed the search from his router and it won't find the AiMesh node router! I went through the trouble of factory resetting both routers again, even swapping them, setting up the new router as the router and the old router as the AiMesh node. Neither will find the other! I even put the router in AP mode, like I have mine in, and it wouldn't find it still.
All three routers are running the same latest firmware version, 3.0.0.4.384_20379.
I contacted ASUS support, and they escalated to their engineers, who have yet to get back to me.
Any tips on what I could try next to get this working?
