AiMesh Dual WAN (one failover) Config Question
MadGoat
Hello,
Due to location constraints, I cannot plug both WAN connections into the main router. I'm curious is the config in the included diagram is possible? (One WAN would be failover only, not looking to bond or aggregate)
OzarkEdge
Part of the Furniture
Hello,
Nope... must to be...
ISP(s)/WAN(s) <wire(s)> router/firewalls <wire/wireless> node
OE
Tech9
Dual WAN failover with WAN + LAN doesn't work in Asuswrt anyway. Some people report success with WAN + USB.
