AiMesh Gigabit Internet Slow Speed
rsunny2012
Hello,
i am having 1 Gbps internet speed. i have 2 routers connected in Aimesh setup
Main Router: GT-AC5300 connected to Modem
Secondary Router ( Upstairs): GT-AC5300 Connected in AiMesh setup ( with Ethernet wired connection from main router)
When i connect 1 Computer to Secondary Router ( Via Aimesh setup with LAN cable), i am getting around 950 Mbps Speed. But when i connect second laptop to the same Aimesh router ( Lan cable), i am getting around 200 to 250 Mbps Speed. ( i am not testing speeds on both computers simultaneously. i am testing speeds at one at a time)
if there are multiple connections to the Aimesh router, i am getting less internet speeds. when i disconnect 1 laptop and only connect 1 laptop to Aimesh router, i am getting full Gigabit speeds
i have removed AiMesh and connected 2nd router as Access Point.
when i connect multiple devices to the secondary router, i am getting full speeds ( up to 950 Mbps)
why is this happening ?
i am on 3.0.0.4.384_45149 firmware on both the routers
OzarkEdge
Part of the Furniture
Hello,
Don't know. Did you set the node properties for Ethernet backhaul connection type just in case it's falling back to wireless backhaul?
When you setup AiMesh, did you reset to factory defaults before configuring the router and adding the node?
OE
rsunny2012
yes i have connected the aimesh router via wired ethernet. i have ressetted the router before configuring it as aimesh node
if i connect 1 laptop, i am getting gigabit speeds ( around 950 Mbps). if multiple devices ( or even 2 devices0 are connected to router, i am getting only up to 200 to 300 Mbps
OzarkEdge
Did you set the node connection type to Ethernet to force it to use the wire or is it set to Auto?
OE
rsunny2012
i have downgraded my firmware to 3.0.0.4.384_32799 . now everything is working fine
i am getting good speeds
i think in latest firmware, 2nd 5GHZ is dedicated to backhaul channel
