I have a AX3000 as primary router, and 2 x AC68U as nodes in the aimesh, wired backhaul, all is working but I'm slightly confused on the guest network
Current config
AX3000 primary - I have 2 wireless networks configured, 2.4GHz named net1 and net1_5G, all works as expected.
I then created a guest network, first using the 2.4GHz option ,so now have net1_guest, intranet access disabled, just as I want, and this works well.
Do I need to also created a 5GHz (net1_guest_5G for example) as well, if I want the 5GHz in the guest mesh? It seems like I should.
Current config
