Solved AiMesh Location names.
flyingwolf
Is there any way to change the names or add more names or locations to the location for the AiMesh nodes?
Right now there is a limited set and it would be nice to be able to customize them as there may be more than one in a bedroom and naming them correctly is important.
Just go to the AiMesh tab, select the node name drop down list and at the bottom 'custom', select and and edit.
I don't bother... one less setting to muck around with.
OE
Unfortunately, that option does not exist.
OE
While that may be true, it also means it is harder to troubleshoot when you have to choose a random location rather than the actual location. Especially if you have more than one AiMesh node.
Alright.
I got the updates done, it took about 2.5 hours for the interface to stabilize to the point I could use it, which was a bit concerning. But things are all working great now and the new names are assigned, thank you all.
