Does anybody know if there is a maximum of 8 wired nodes? I have a setup like this:
Everything is wired, after numerous tests I am very confident the wiring itself is no factor. As you can see, the systems starts with an AC86U. This is connected to a (factory setup) Zyxel GS1900-24 switch, which in turn connects the nodes. Up to 8 nodes connect wired; each and every node I connect beyond that number will only show 5G connection, although on the LED's WAN (internet) is being lighted continuously. All routers are updated to the current ASUS firmware. I have tested switching different nodes and it does not matter specifically which node I connect beyond the 8th. Even after switching between nodes which connected wired in the first occasion, they loose wired connection if they are connected beyond the 8th. As a test, I have had 10 nodes connected but only 8 will connect wired.
Is this normal system behavior or am I missing something?
