AiMesh Node and VLAN
ShevAmeMG
Hi folks,
I have a small network at my place with AiMesh to cover the whole area. I've just switched my provider and their TV is over IP, so I've set the VLAN on the main router on two ports, so the TV boxes work properly there. The catch is that I also want to have TV on the second floor, which require to either pass a cable all the way there from one of the assigned IPTV LAN ports or, if possible, map a VLAN port on the node. Is the later possible at all? Ofc I've already tried connecting to the node but with no success so far.
Any help or suggestions are really appreciated.
Thanks.
