silencereno
Hi, my situation is use AX86U as main router, and AX56U as AiMesh Node point, both WIFI work and have strong signal. The problem is when I connect my QNAP NAS (TS-253D) via ethernet cable to AX56U (Node) LAN port, NAS can not be found. Same as my Macbook pro connected to LAN port via USB ethernet adapter and No internet connected. Is there any setup to be done to make Node LAN ports work? Really appreciate if anyone can help here. Thanks.
