I have an RT-AC5300 triband router and an RT-AC68 node. This setup seemed to work fine. However, I added an RT-AC3100 (dual band) node to the mix and things got add. After adding the RT-AC3100, the AIMesh decided to use 5GHz-2 as the backhaul. I see the 5GHz-1 SSID throughout the house, it works great, as does the 2GHz SSID. However, when I look at the clients on the RT-AC5300, there are no clients connected on 5GHz-1.
In fact, if I turn off both mesh nodes, the 5GHz-1 SSID is not broadcast from the RT-AC3100. I am assuming something is going on with a triband router connecting to dual band nodes. I still want my RT-AC5300 to use 5GHz-1 and handle wireless clients. What do I need to do?
Thanks!
Thanks!
