1. Post filters have been ramped up due to high spam activity. If your post is marked for moderation, be patient. A moderator will review and release it as soon as possible.
    Dismiss Notice
Dismiss Notice
Welcome To SNBForums
AiMesh on the T-Mobile TM-AC1900
Discussion in 'ASUSWRT - Official' started by DHume, Oct 20, 2017.
  1. nightanole
    nightanole Occasional Visitor
    Mar 21, 2014
    25
    No clue. 1.0.2.1 is not listed in the trx folder. Believe it or not the tmobile 2.1.2.6 cfe is there, along with the C0 rev for the 1ghz ac68u.
    Ill be bricking mine soon so ill let you know if this new trick fixed the tmobile issue :p
    Adam likes this.
  2. Carbon658
    Carbon658 New Around Here
    Oct 20, 2017
    6
    I'll be very curious about your process and experience.
    Adam likes this.
  3. Adam
    Adam Occasional Visitor
    Oct 21, 2017
    14
    I meant that if 1.0.2.1 cfe was already flashed. Trying to theorize as to the conditions for the cfe update to occur while flashing the beta firmware.
  4. vicantu
    vicantu Occasional Visitor
    Mar 9, 2016
    10
    I only have OSX (Mac) and cant install 7Zip, can I find this file anywhere else to update my TM-1900 converted routers? Thanks
  5. Adam
    Oct 21, 2017
    14
  6. nightanole
    Mar 21, 2014
    25
    welp i wasted an hour. Got both of them flashed to the "new" 1.0.2.0 and still no luck.
    On the bright side i didnt brick anything. And yes i did to the hex edit manually for the mac and secret code.
  7. vicantu
    Mar 9, 2016
    10
    Have you tested this or is a "theory"?
  8. nightanole
    Mar 21, 2014
    25
    Its a theory.
    It didnt work for me. I assuming the file size difference in the cfe's is due to the "internet" version having overclocking enabled.
  9. vicantu
    Mar 9, 2016
    10
    did it actually work for you @goggles99 on your TM-1900 routers or you write that as a theory?
    Have anyone had success on making converted TM routers "aimeshed"?
    Peace
  10. Roy2001
    Roy2001 Occasional Visitor
    Nov 14, 2016
    36
    Apparently, it did not work. Otherwise it is not a theory.
  11. Shadowsteps
    Shadowsteps New Around Here
    Oct 22, 2017
    2
    I have the same setup. Anyone here has any luck with ac68R and Tmobile ac1900?
  12. Carbon658
    Oct 20, 2017
    6
    No it looks like we are on our own until whatever is excluding these units is found.
  13. tabney
    tabney New Around Here
    Oct 23, 2017
    3
    I recently installed this on my AC68R and my converted AC1900 (AC68U). It has been up and running for 3 days now with no problems. What errors are you getting?
  14. nightanole
    Mar 21, 2014
    25
    Everyone has the same "problem", the base can not find the nodes. Based on meta data, its not the cfe, since we have tried all combos. Its possible yours works because you have 1 real ac68u.
  15. tabney
    Oct 23, 2017
    3
    I had to reset my node twice in order to get it connected. Since then I have not had a problem with it connecting and staying connected. My AC68U is a converted TM-1900.
  16. nightanole
    Mar 21, 2014
    25
    Since we are gathering information, is the converted tm-1900 the base or the node?
  17. Craig Chapman
    Craig Chapman New Around Here
    Oct 23, 2017
    1
    Awaiting an update on this before I pull the trigger on 3 TM-1900's
  18. nightanole
    Mar 21, 2014
    25
    Save your money. It has been confirmed by several people that a system of just tm-1900's will not work with any of the betas and any of the cfe's. 1-2 people have got a real ac68u and a tm-1900 to work.
    Craig Chapman likes this.
  19. tabney
    Oct 23, 2017
    3
    The converted TM-1900 is the node, my base is an AC68R.
  20. hvluu
    hvluu Occasional Visitor
    Mar 3, 2015
    27
    Texas
    I got it work last week but due to the need of selective routing on Merlin, I flashed the main router (AC86U) back to Merlin beta. However, my AiMesh consisted of the AC86U as the main router and the TM-1900 as the node. But The TM-1900 that I got from Tmobile a long time ago when they first announced it (in 2014 maybe) and I converted it to AC68U. Hence I couldn’t remeber which CFE I flashes. Both was running the 10/12 lastest beta.
Share This Page
