lilstone87
Well here's my question/concern. I have a two router setup, one as the main router, second as a mesh node. What I'm curious about, is if my clients will only connect to the router with better signal, when it first connects to wifi? So say one router is located where most devices enter, so they first connect to it(main router). However most devices end up being located closer to the secondary router, while within the home. How is this handled within AiMesh?
Because just a few minutes ago, I was connected to the secondary router with better signal. Yet I ended up moving closer to the main router, so my device dropped a bit of signal. The device was not active for a few minutes between this movement, so I expected when I started actively using it again, it would auto connect to the closer router. However that didn't happen. So to me.. what's the point of AiMesh, if the device is only gonna connect to the closer router, upon first connecting to the wifi?
In that case, my secondary router is able to be connected to the main router wired. So would I be better off running the secondary router in standard AP mode, with different SSID, and such? Because I honestly thought with AiMesh in place, devices would seamlessly switch to the router with better signal, not wait till the device connects/reconnects to wifi, to do so. Is there a minimum signal level I'm not aware of, before the device will try to swap to another node with better signal?
