AIMesh Remove replace node
mogulman
I currently have an RT-AX86u as my main router and an RT-AC86u as a node. I'm getting another RT-AX86u. Can I just remove the old node and add the new AX86 as a node? or do a I need to reset the main router first?
RMerlin
Asuswrt-Merlin dev
Only reset the node.
Adooni
yes you can, but in same situation you can hit bug that new node cannot be added. In such case you need factory reset main router and back to router mode for nodes and add nodes to main router and configure main router.
OzarkEdge
Part of the Furniture
Removing the old node will reset it.
Reset and add the new node. You would only reset the main router to configure it from scratch.
OE
