JokerPower
Hi guys
I've enabled the second 5GHz band on the RT-AX92U. The speed now is much better when connecting to this band.
But there is one thing I don't like about it. Almost every device connected to this band tends to disconnect and connect to the first 5GHz band (which is slower). It seems like the first band has a higher priority or smth.
This happens even in the same room with the router.
I'd like to mention that both RT-AX92U are connected through wired.
Why does this happen? Can it be fixed?
Many thanks
Many thanks
