Aimesh Sticky Client Issue
ComputerSteve
I have had so many problems with AiMesh not reliably being able to kick my Mac even with roam assistant enabled and the setting changed to a drastically low number. I read about this and apparently it’s a known issue something that has to do with sticky clients. Does anyone have any suggestions on how to fix this problem. Do any Merlin compatible routers actually roam properly. Right now I have a GT-Ax11000 pro main router and 4 XT8 Nodes and the Mac will never roam. This also happened when I had the RT-AX88U and RT-AX86U node combination. I can forcefully make it roam by disconnecting the client and then re-enabling it but it doesn’t do it automatically. I also found that if there was a way to make AiMesh use this type of BSS request
disassoc_imminent = 1 instead of what it currently does of = 0 it would work. However without scripts and using HostAPD it’s not possible.
